Brief Description: Rivet Bottom Rear and Bottom LE Skins
Drilled the pilot holes in the flap hinge and mounted hinge to the wing.
Riveted the rear line then rib lines moving from center out and forward. Removed the clecoes and finished the rear skin first. Riveted the main spar line center out 4 rivets left then 4 rivets right out to the ends. Changed tips and riveted the nose ribs and pitot tube in place.
