After marking all the spar cap holes and nose rib centers it was time to remove the LE skin from the bottom and finish laying out and drilling the pilot holes.
Image 2) Block the rear and raise the front only to remove the clecoes from the bottom.
Image 3) Moved the PVC tube forward and only lifted high enough to remove the clecoes.
