Positioned banded part on the clean work table, set 10 down stops at 58mm and set some uprights to prevent 3/4 MDF from slipping off the back edge. Positioned the 3/4" MDF over the part then positioned the 2 x 2 x 4 steel beams and clamped one edge.
Image 1) Entire 4' x 12' table is covered and clamped lightly to the 58mm stop blocks.
Image 2) End view of clamped press.
Image 3) Done for the night, SEWPRO will sleep inside tonight.
