Brief Description: Make fixture for wing light lens
Move the straps to the back of the forms so it doesn't deform the metal. Tighten the straps and insert screws from the leading edge back.
Image 2) I noticed a little difference in the radius size between the end forms so I used a slapper to tune it up a little. Be careful here you might make a dent and have to start over. Over all the metal behaved well and I think I will use 1.75 stops when I make the LE Skins.
