Brief Description: Cut and began fitting bottom wing skin
Took all the fixturing off the table top and taped Poplar strips to the 2 x 2 steel beams. Didn't want to scratch the upper wing surface. Flipped the wing over and pulled out metal and cut one more bottom wing skin.
Set angles and leved skeleton.
Layed out the rivet lines on the skeleton then placed both sheets on skeleton, that way Anne can park her car in tonight.
Talked to Caleb about the missing 102mm dimension on the bottom wing skin print. I think I will order the Hardware Box from them, their prices are good and they have earned my support.
