Image 1) Clean off the table so work can be done. Noticed the spar tip angles got primered on the wrong side. Set up temporary table on Anne's side of the grangar and set all the parts over there. Cleaned up the work table and adjusted the riveting machine. It had gotten lose after hammering all the wing spar rivets.
Image 2) Clecoed the spar caps at the ends, inserted the bolts, added the angles and their rivets, added all the other rivets. Taped everything down to the web before flipping over.
