Brief Description: Wing Spars, Deburr & Prep for primer
Deburred and flanged the Right Wing Spar.
Here are some pictures of the 1 ton arbor press / rivet maching I plan to use. I was able to make up a couple peices in the lathe to hold the $1.95 rivet squeezer tips from ACS. Got the idea from Herb Heaton but I will be using a rawhide hammer on the ram. The peices are long enough to stay away from the flanges and large enough to setup a rubber cushion if needed.
