I made a mistake when I bent the flanges and was able to save it buy re-stacking the spar caps to the other side of the web and using the spar angles from the other hand part. I opened up the 6-14 holes to #11 and ran another #20 through the 5-9 holes. Now I know why you want to square up that drill press. I will only need a few repair rivets to keep it all within specs.
