Brief Description: Drill spar caps with square drill press.
I did a little thinking here and figured the work table is real flat and stationary, what would be an easy way to move the part past the drill press. Here is what I did. Out came the router and I cut two long groves the length of the table. These are so the clecos don't snag when moving the parts.
Next the visqueen goes on the table then the part goes on top ot that. It slides real smooth and doesn't leave scratches..
The position and square up the drill press. The drill press bed is cranked up to touch the lower beam of my work table. Helps steady the whole setup. I will be using a stronger table, not a milk crate, for the final hole sizing.
