Finished to size 3/32" the bottom & forward wall of the Right Aileron.
Flipped it over and had to fixture the part to draw the 45mm rivet line in to place. Clecoed that line first then worked the metal toward the trailing edge. Notice the bar clamps under the aileron pullung against the 2 x 4. Light clamp pressure was all that was needed to get the line centered in the rivet holes.
