Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Nose Bowl
Cut center recess for spinner/prop hub
Center turntable on milling machine. Center disk on turntable and clamp down.
Offset radius and cut arc, Clear out to center, rotate and do other side.
Reset hold downs and clear out remainder of material.
Screw down to backbone on center.
Store for later and begin cleaining up the shop.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
