Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Nose Bowl
Set disks down into frame backbone
Need to layout cut lines to set the disk down into the back bone and stations.
The center piece is 280mm up from base and the highest points of the air inlets are 285mm.
The right side cut line is 50.5mm deep so the new station height is 220.5mm for the bottom of the right air inlet disk.
I set the stations in place and struck an arc equal to the radius of the disk to establish the verticle cuts on the stations.
Saw cut to the lines, the heights are good but the 7 stations need rework to blend the shapes
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
