Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Modify rotor plate
Keeping the bushings soaking in oil.
Wiped off the oil, set the template and marked rotor plate to provide the mechanical advantage I suspected. Spoke to WW and he confirmed the thought.
Ground away the ramp and deburred.
Soaking bushing in oil
After grinding
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
