Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Finish bore Distributor ID
Picked up Distributor body from BallOMatic.
Retrammed on lathe and brought the finish out to .4895
I stopped because to build up enough tool pressure I could go over on size. Decided to use Roy's Hone to bring the size in to spec.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
