Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Distributor
Machine OD of bushings
Made madrel out of the 3/8 bolt by facing, center drillining each end and setting it up between centers on the lathe.
Set spacers and snugged up nut to hold the two bushings still.
Machined to .654" od This will allow for .007 clean up cut on the distributor ID.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
