Ron Lendon's Aircraft Mfg.
Date:  11-10-2009
Number of Hours:  3.00
Brief Description:  Make boring bar to size distributor bushings
Make boring bar for distributor bushings from 5/8" drill rod. Could find one long enough to do the job.
Turned shaft down to .4" OD, drilled and tapped 8/32 hole in end to retain tool bit.
I will drill a 7/16 hole in the bushings and start boring from there.
5/8" Drill Rod
Turned down
Turned down
Drilled & tapped
Drilled & tapped
