Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Main Gear
Bolt holes for axel 2 of 3
Placed a strong clamp and drill one hole and place a bolt through and tightened. Drilled next hole diagonal and bolted it also.
Drilled the next two holes after removing the clamp. Used lots of Tap Magic and cleared chips often, about 5 pecks or more to get through.
Flipped guide to outside, bolted two holes diagonal then reamed other two holes. Bolted the reamed holes and removed others and reamed them also.
Strong clamp
Bolted to drill next two
High speed hand drill
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
