Ron Lendon's Aircraft Mfg.
Date:  4-11-2009
Number of Hours:  1.00
Manual Reference:  WW Nose Bowl
Brief Description:  Cut center recess for spinner/prop hub
Center turntable on milling machine. Center disk on turntable and clamp down.
Offset radius and cut arc, Clear out to center, rotate and do other side.
Reset hold downs and clear out remainder of material.
Screw down to backbone on center.
Store for later and begin cleaining up the shop.
