Ron Lendon's Aircraft Mfg.
Date:  2-28-2009
Number of Hours:  3.50
Manual Reference:  WW Nose Bowl
Brief Description:  Set disks down into frame backbone
Need to layout cut lines to set the disk down into the back bone and stations.
The center piece is 280mm up from base and the highest points of the air inlets are 285mm.
The right side cut line is 50.5mm deep so the new station height is 220.5mm for the bottom of the right air inlet disk.
I set the stations in place and struck an arc equal to the radius of the disk to establish the verticle cuts on the stations.
Saw cut to the lines, the heights are good but the 7 stations need rework to blend the shapes
