Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW Nose Bowl
Making top stations for nose bowl station buck
Measured and cut top side stations, spaced them 100mm from center line.
Setup router to make light cut for stations to set in, the glue will hold better this way also.
See the cut, slot for station?
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
