Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-b-2-8 & 9
Upper & lower rudder bushings for rudder
Started with 4130 .25" dia. rod and drilled a .1875 hole about 1" deep on the lathe.
Faced the end then used parting tool to cut tube pieces to length.
Then it was just a matter of holding the small parts with a hand chuck to deburr them.
Didn't have the tube so I made some.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
