Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Framing right wingtip 2 of 2
Drilled the lower long piece and clecoed it the the skin using the tangent lines as guides for position with the skin edge.
Drilled and began shaping the upper rear frame piece. The hole pattern in this part is offset 20mm so the rivets don't hit each other
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
