Ron Lendon's Aircraft Mfg.
Date:  9-20-2008
Number of Hours:  2.50
Brief Description:  Clean off primer and layout wingtip trim line
Used lacquer thinner to clean off the excess primer.
Fliped wing over, added L-angle to rear spar and clamped a long piece of straight angle to transfer a cut line to the inside of the wing surface. Just blued it up and lightly scratched a line using a scriber.
