Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Fitting fuel filler flange 7 of 8
Rough in the trim with a dremel tool carbide cutter, finish up sanding with large drum sander turing slow in drill motor.
Notice the plastice template material taped over the fuel tank inlet to keep the debris out.
Picture of template
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
