Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-WLO-1
Wing Locker trim out hole
Used the trimmed door to layout the hole by lining up the front edge and balancing the distance between the rear rib 4 & 5 rivet lines. Drilled holes about 1.5" inboard from the trim line.
6-WLO-1-1 cover
Big step drill
Ready to snip
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
