Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-W-8A
Right Rear Bottom Wing Skin
I started to run out of silver clecoes so I used two in each rib and moved em like this from main spar to rear spar. I know it's backwards from the plans it just needed to be done this wat to get everything coming out the way I wanted it.
Line up and drill over two
Move one silver and drill
Add two copper clecoes
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
