Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6-W-7A
Rear rib assembly process 2 of 3
Center punch in the center of the line on the rib flange
Drill one pilot hole hole (silver cleco)
Cleco the one hole, line up the line and mark the bottom hole through the web.
Remove rib cleco and center punch and drill the next hole in the flange.
Center punch on line
Drill the one hole
Mark the bottom hole
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
