Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Finishing touches on the wings 1 of 3
Today fastened the Strobe, Set the flaps, Tested the Aileron and made the routing for the wires.
Used string to see where everything would be, then drilled holes for the rubber grommets.
Setting Flap Hinge
AeroFlash Strobe
Rubber Grommets
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
