Ron Lendon's Aircraft Mfg.
Date:  3-24-2007
Number of Hours:  1.00
Brief Description:  Set flaps 4 of 4
Set the 5mm gap from the Aileron and remove the Aileron. Mark the hinge ends on the flap.
Image 2) This is because I made the mistake of riveting the bottom skin flap hinge. Trying to see if I can fit the flap hinge to the flap. Got it temporary clecoed then took out the hinge pin and set 5 A4 rivets in the flap hinge. Put the pin back in to check fit and alignment. Made some adjustment and clecoed the whole length out to the A5 rivet size.
Set 5mm gap
Set 5mm gap
Cleco the ends
Cleco the ends
Cleco the rest
Cleco the rest
