Ron Lendon's Aircraft Mfg.
Date:  3-3-2007
Number of Hours:  1.00
Manual Reference:  6LLO-1
Brief Description:  Cutout LE skin for the Land/Taxi Lights
Checked the dimensions and location one more time before cutting that beautiful LE Skin.
Image 2) Drilled holes close (5mm) away from trim lines. Ran 19mm holes in and snipped out the middle of the hole. Start slowly from one corner and use both pair of snips, cut a little with one and then switch to the other hand of snip and cut a little more. Make the distortion go towards the middle piece. Made first rough trim, then trimmed hole edge to hole edge to get closer. Then used a rotary file to bring the corners close to the radius trim lines.
Image 3) Next it was trim to the line, a little clean up with a file should finish it up
Beautiful LE Skin
Beautiful LE Skin
OMG! What happened?
OMG! What happened?
Little clean up needed
