Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
WW
Picked up the crankshaft from Moldex
The crank has 5/64 radius on both mains & rod journals. I did a quick check with calipers and all looks good.
5/64 radius
Tapped End
They mark the under size
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
