Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6K1
Layout & Trimmed fuel tanks
Have both tanks on table, making Left & Right layouts.
Talked to Travis @ Zenith and found out the flange goes inside the tank now. Found it in the release notes but needed clairfication.
Using the outer ring to keep everything lined up to tack the flange on the inside of the tank.
Both tanks on table
Filler hole
Flange is on the inside now
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
