Ron Lendon's Aircraft Mfg.
Date:  12-3-2006
Manual Reference:  6K1
Brief Description:  Fitting ends of fuel tanks
Fitted the radiused corners to the tank skin. Looks like everything is going to come out just fine. Once the beads are in the skin a couple taps with the hammer should bring the edges together for the Weldor. Still have to layout and cut everythin and get some tubing for the vents.
This is the worst one
about 3mm gap
about 3mm gap
