Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W4 & 5
Finish spars, test set dihedral
Finished center spar, angles, flanged holes, A5 rivet line, and layout notch trim.
Added spar tips to the spars.
Set it all up to set the wing dihedral. 355 up and 3588 over.
I will let it set overnight before drilling the six 5/16 attach bolt holes. Might wanna put it on the mean -5mm.
Finished Center Spar
3588
Need all the table for this.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
