Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
6W3
Wing Spars, re-fit spar caps & angles
Re-Assembled the right spar and had Anne check it to see if I had it right this time before I bend anything.
Inspector checked holes again and they are within tolerance so the fix rivets won't be necessary.
Side by side to get bend right
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
