Ron Lendon's Aircraft Mfg.
Date:  9-11-2006
Manual Reference:  6W6
Brief Description:  Qualifing rear wing ribs
I used the flanging pliers for some major adjustments to the flanges, then found out it was faster to use my hands/fingers with gloves for fine adjustments. Checking along the flange with the square while holding the rib down in the middle gives very good results. You can see very clearly where and what way it needs to move.
Adjust rear to 93.3 degrees
Adjust all others 90 degrees
Getting between crimps
