Ron Lendon's Aircraft Mfg.
Date:  8-28-2006
Number of Hours:  3.00
Manual Reference:  6ATO-1
Brief Description:  Forming Aileron Trim Tab
I made another test strip and broke it up using the leaf brake. This one came out better because of the order of bending, 131 degree, 65 degree first. Tune the bend angles (qualify) of both bends first then make the final bend. Only able to make it about 95 degrees in the brake. The rest will be done on the table using clamps.
Test strip 2 & Trim Tab Skin
Aileron Trim Tab Skin
