Ron Lendon's Aircraft Mfg.
Date:  5-22-2006
Number of Hours:  4.00
Manual Reference:  6T6
Brief Description:  Elevator Trim Tab
Setup cutting table to cut and bend the 6T6-3 Elevator Cutout Channel. Made the part and fitted it into the Elevator. Had to remove the rivets from the end rib to be able to get it in there, left the forward rivets in place. Fitted 6T6-3 by trimming the middle rib end and marked the rivet line.
Cutting table
Cutting table
Lossened the end rib.
6T6-3 in place ready to pilot drill
