Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Wing root doubler
Turned wing around to finish up the LE work
Riveted nose ribs 4 - 7 back in place.
Clamped and transferd hole centers to .125" wing root doubler. Drilled and reamed all holes. Bolted and torqued all but the rib and L-Angle bolts.
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
