Ron Lendon's Aircraft Mfg.
Date:  6-16-2010
Number of Hours:  1.50
Brief Description:  Flipped wing and riveted end frame back in
Wired landing and taxi lights and reinstalled the lens.
Put fuel lube on filler neck and reinstalled it.
Riveted most of the end frame back in, had to leave rear top free to install the weights on the aileron balance arm.
Flipped the wing over and riveted the bottom spar cap between the first 5 rear ribs.
