Ron Lendon's Aircraft Mfg.
Zodiac CH 601 XL
Prep Ailerons for LAA mods
I ain't measuring this time, just use plane geomerty. Square up to the nearest rivet hole that will work, mark the hole and build it inboard from there. I just happens to work out perfectly for the rib flange spacing also.
Aileron is standing on its end
CZAW CH601XL Home
Zodiac CH 601 XL Home
3634
225
358
Facilities
57
177
Flight Testing
1137
Maintenance
Nose Gear
Planning
185
1054
ZU601XLB
