Brief Description: Final trim of lower edge of Rudder skin
Fitted skin once again using the 2" risers and 3/4" spacer and found another 2mm could be safely trimmed off the lower edge. This will keep the edge/hole tolerance and make the skin edge blend in with the radius of 6T4-6
