I did more work on the wiring today, On the passenger side there are a lot more wires to go up to the panel, on top of that you have the pitot/static tubes that need to be guided from the panel to the right wing there as well. I decided to put the wiring and the pitot/static tubes together in some conduit that is attached to the fuselage sidewall with J.B weld, much cleaner this way. I'm nearly finished with the wiring, soon I'll be able to test it all but not this week As I'm going away again to NZ on a business trip. Maybe next weekend.
