In installed the anchors for the cable ties on the fuselage today. These are plastic ties that come self-adhesive. The adhesive needs to be removed as it won't hold up to the vibrations, this is done by soaking it in some acetone for a few a few hours. They are then attached with J.B. Weld to the fuselage. I also did most the ground wiring today.
