Brief Description: Copying the holes in the forward wiing attach angl
After removing the old forward wing attach angles from the fuselage I cut the side leg off the angles so they could be used as a template to copy the holes that attach them to the spar tunnel. As you can see in the last picture I've made 2 sets of new forward angles, as mentioned before I will use one set to try and use the enlarged 3/8" hole to drill the new ones in the new angles, I think I'm going to cut up a Coke can to make a small bushing which will allow me to center the 3/8 drill in the enlarged hole. I'm not sure if this will work, the position of the new hole might not fit the hole in the attach blocks precisely, we'll see, if it doesn't work I'll be able to swap the angles with the second set and drill a hole through them from the back of the fuselage.
