Brief Description: Riveting the ribs and rib #9 work
I finished riveting most of the ribs to the skeleton although I did not do ribs 1-3 yet as I need to be able to remove those for deburring the holes I drill out when installing the root rib. Also I did not rivet rib #9 yet as it still requires installation of the aileron belcrank. After that I started to do some work on rib #9, I installed the stiffener channels I made earlier.
