Brief Description: Priming, aileron pushrods and pitot/static tubes
Great progress today, I started off touching up the whole skeleton with the primer, some damage was done to the primer installing and removing the skins multiple times, also the holes drilled in the spars and ribs needed to be spot primed. Once the primer was dry (this green ecoprime dries in about 30 minutes) I went ahead and installed the aileron pushrods, probably a good time to do this while I still have access from both sides. Finally I put the pitot/static tubes in place as well. Everything is ready now for final assembly, I just want my TC to have a look at it before I close it all up.
