Michaels Sonex #145 log
Date:  7-25-2013
Number of Hours:  0.80
Manual Reference:  W21
Brief Description:  Rib #9 work
I drilled and installed the belcrank and support channels in place on rib #9 and then installed the rib back in the skeleton, this will make it easier to correctly position the little angles that attach the support channels to the wing skin. Once the fwd skin is done I will have to take the fwd skin back off, install the aft skin and do the same.
