Michaels Sonex #145 log
Date:  5-25-2013
Number of Hours:  1.50
Manual Reference:  W18-01
Brief Description:  Bending the leading edge wing skins
Bent one of the two leading edge wing skins today, how easy was that, the vacuum method is great.
It took a bit of time making sure the skin was centered correctly. After that you need to pull the edges together initially with some masking tape, finally it's just a matter of taping the plastic sheeting together and finally sucking the air out with a vacuum cleaner.
Simple, nothing to it, I was impressed.
I will make a video when I do the second one to demonstrate how easy it realy is.
