Before I start assembling the wing skeleton, I need to form the forward wing skins whilst I still have the room around my working table to do so. I will use the “vacuum method” to do this. Tonight I laid out the skins and drew a line and some markers to correctly place the 40mm pipe around which the bend will form. That’s all I can do for now as I don’t have the material yet, tomorrow I will to pass by the hardware store to pick up the pipe, plastic sheet and fasteners that I will require to make the bends.
